Home > Puma (Tdci) > How to repair the front air vent |
a new small hole...
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
27th Feb 2017 9:32am |
Repaired! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
27th Feb 2017 12:17pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7866 |
Do the vents just pull out or are they fixed in at all? I want to remove for painting the silver circle at some point. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
27th Feb 2017 12:31pm |
Just pull out Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
27th Feb 2017 12:44pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
looks like something sugru was made for Mike
27th Feb 2017 3:04pm |
Dreamweapon Member Since: 19 Dec 2016 Location: Hessische Odenwald Posts: 55 |
@JOW240725,
I suppose it is a personal taste thing, I have spent the last few months getting rid of all silver on my 110, I have finally achieved the effect below. 'Every time you try and operate these weird black controls that are labeled in black on a black background, a little black light lights up in black to let you know youve done it. - Zaphod |
1st Mar 2017 12:40pm |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
Ditto, I want to touch up the paint on the silver ring... (likely to black)
It aint coming off using my fingernails at the moment, so I carefully apply force on the outer rim with something like a flat blade driver until it pops? Or is that going to break it? Solved the bowel problem, working on the consonants... |
1st Mar 2017 7:08pm |
Thank you, I'll give it a try Won't be going black, just a different shade of grey James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
1st Mar 2017 7:59pm |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 494 |
There are three locating tangs. I had the dash centre pulled forward, got my hand in behind and pressed two in together and the vent came out easily. Pulling out the centre dash is pretty straightforward. Current Steeds:
2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
17th Mar 2017 11:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19454 |
Should see the doctor about that. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
17th Mar 2017 11:07pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 570 |
As ridiculous as it sounds, I wanted to paint up some additions on the interior in the same silver/ grey as is already in there. Once I started to try and identify the shade realised the vents are different to the instrument dials.
In the end I matched in with the dials, they are the darker Land Rover Brunel colour suffixed with a 1 in the colour code. So now the brighter silver vent rings are bugging my OCD and I will add that to the list. |
17th Mar 2017 11:49pm |
