Home > Maintenance & Modifications > aluminium oxidation |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
any one treated the aluminium corrosion to the doors etc , some have said vinegar solution , before painting .
24th Feb 2017 8:45pm |
Yes respray.
24th Feb 2017 10:43pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19535 |
Ah yes, pretty sure vinegar it is as suggested here.
For some bizarre reason when I posted earlier I thought you meant Alu Chequer plate. My fault. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
24th Feb 2017 10:49pm |
is it ok to after washing in vinegar ,then ok to use filler then primer and top coat ,or coat the surface after washing ,with a primer then filler ?.
25th Feb 2017 10:08am |
just done a search on the net , seems the thing to use is Alodine 1201 none as bonderite c-ic33 , but can I find it in the uk nope .
used a lot on aircrafts to stop, just the same rot as on the landy . |
25th Feb 2017 11:40am |
I'd opt for primer, filler, epoxy sealer, paint base, clear.
Obviously there is the sanding steps in between, don't use wet and dry wet though with filler as its porous and will take on moisture. Use it dry. Panel wipe also needed for each step, but I don't panel wipe between base and clear, everything else I do. I'm sure you know all of this anyway. Masking wise there is some nice very cheap polythene dust sheets on eBay for just a couple of quid and some blue 3m masking tape would be helpful too. After the vinegar just make sure it's panelwiped, Upol 20 fast wipe would be ideal. Beware of its fumes, use in well ventilated areas. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
25th Feb 2017 12:02pm |
Many thanks for all the info, great, goes along with what I was thinking of doing, might try and get some of the aircraft stuff first, but last resort, vinegar it is.
25th Feb 2017 12:28pm |
Hope all goes well. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
25th Feb 2017 2:03pm |
