Home > Tdi > Veethree tachometer - anyone with experience? |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
After doing some digging about on there website it looks as yours is a programmable type :-http://www.veethree.com/programmable-tachometers.html
The gauge should have come with a chart so you can set your dil switches to the correct setting for a 4cyl alternator driven signal. Kind Regards Will 2005 90 XS 1954 86'' Series 1 tilt |
23rd Feb 2017 12:27pm |
Boost Member Since: 17 Oct 2014 Location: Gloucestershire Posts: 198 |
Thanks so much Will
It turned out there was a rubber bung you can remove and behind it some switches to configure for 4,6,8 cylinder etc. It works now and I'd rate them, about a third the price of a VDO unit and solid metal and glass construction. Cheers Boost |
23rd Feb 2017 8:26pm |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
How did you wire it, , and what sort of Revs, does your Tdi cruise at, [ speed - rpm, ] ?
23rd Feb 2017 8:59pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
I have got one of these on the shelf but have yet to pull my finger out and fit it Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter |
24th Feb 2017 1:07pm |
So far it idles at about 800rpm and max around 4,000 but not sure how accurate it is.
One wire from the 'W' post on my Marelli alternator (meant for a 300tdi but take the serpentine pulley off and it'll fit the 200). 2 wires for positive and earth. You should fit it, seems quite the luxury having a working tacho on an old landy! |
24th Feb 2017 2:59pm |
