Home > Tdi > 200tdi Fluid Changes |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2545 |
Here you go, straight from the manual.
Click image to enlarge I use semi-synthetic 10W40 oil in mine, just standard cheap stuff from the motor factors. I buy it in drums as I'm doing the 6k service every 6-7 weeks but doing such a small mileage as yours I would change engine oil annually. Edit: Uploaded wrong pic! Corrected now. |
21st Feb 2017 9:54pm |
Also, bear in mind the manual was written in 1993. As such don't worry too much about brands, just get the right type of oil and you'll be fine.
21st Feb 2017 10:01pm |
Needalandy Member Since: 07 Feb 2017 Location: Edinburgh Posts: 7 |
Thanks for the info. I've read somewhere that recommended gearbox oil had moved on to Mtf 94 is that right ?
21st Feb 2017 11:00pm |
Yes, though many (myself included) still run ATF. It's certainly easier to get hold of and some LT77 boxes seem to prefer it, while others run better on the MTF94.
21st Feb 2017 11:04pm |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 68 |
I use a good decent oil from a local motor Factors in my 200
29th Mar 2017 5:06pm |
