Home > Tdi > My odd engine config and some belt issues |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
Go online and compare belt pat numbers
21st Feb 2017 8:52pm |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 |
Your problem is the "bane of my life" with my 1989 with a 200 Tdi disco engine! I will take some photos for you ....but basically I think you have to make your own plan.
Good luck |
21st Feb 2017 9:32pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2547 |
If I recall correctly on a Defender 200Tdi the alternator/water pump belt is a 10mm and the PAS pump belt is a 13mm, however the Disco lump has a very different belting arrangement so that may be of no use.
Post a picture of your belt setup so we can see what you have, I am struggling to picture it from your description. Standard Discovery 200Tdi belt setup: |
21st Feb 2017 10:06pm |
Defender 200Tdi setup for comparison:
21st Feb 2017 10:07pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
200 Tdi belt system is a pretty crap design to start with and now theyre all at the mileage where the other compontents are getting very worn, inspect everything carefully and buy good quality belts like "Gates" or "Conti". I did a set a few weeks ago and remember being a bit shocked at the price they'd climbed to, odd sizes.
22nd Feb 2017 1:44am |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
Thanks very much guys!
I have replaced belts with standard config Disco 200 main/aux and also re bled my steering pump and it is all working well. I think I had replaced with a pair of Def 200 belts which were similar length but not the same tooth depth which was causing too much resistance. The pump had also got some air in it which I attribute to me not topping the reservoir enough when I did a quick bleed the other day. I now have a nice pair of Conti belts on there thanks to Euro car parts. I think my only confusion now is that I am running a Def alternator on what is otherwise basically a Disco 200 with wrong manifold and turbo. Cheers! |
23rd Feb 2017 7:18pm |
