Home > Maintenance & Modifications > Puma Window blocks - Advice please |
I think the standard ones are made from fairly low grade cast ally, and probably not painted all that well by the body shop. The corrosion seems to start from the face where it goes onto the body which is normally left bare. Some grease on it and a paper gasket would help.
Anodised ones are always going to last a a lot longer than painted ones. I've not got experience of anodised windscreen blocks, but my mini has had anodised brake calipers on it since about 2004 and done about 50'000 miles. No obvious corrosion on them after living in road salt, brake dust and the weather with barely any washing. There is also no reason why you can't paint over the anodising. |
20th Feb 2017 2:09pm |
I bought a set had them shot blasted and power coated .. 5 yrs on and they are fine, blocks are about £10-15 ea and power coating cost £20 ... not much of a saving
20th Feb 2017 2:31pm |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 985 |
I've just fitted the Gore replacements: http://goreproducts.com/products/defender-windscreen-brackets
My original blocks lasted just over a year. Decided it wasn't worth the time to arrange a warranty repair. |
20th Feb 2017 2:33pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
http://www.defender2.net/forum/topic52713.html James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
20th Feb 2017 3:35pm |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 |
Simple fix and permanent and offers so much more as well - get panorama glass fitted! No more need for window blocks, better security and a very clean look for your Landy!!
http://www.vehicleglazingspecialists.com Dave is a great guy and will sort you out, has done two of my cars so far! James |
20th Feb 2017 5:43pm |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 |
That's not going to help keep your windscreen attached to the bulkhead tho James 3 Landrovers
20th Feb 2017 5:55pm |
Thats a very good point - when i read window blocks I assumed meant the ones on the sliding glass that corrode so easily!!
Must read more detail next time!! James |
20th Feb 2017 5:58pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
standard ones wiped over with ACF50 now and again are like new on mine after 5 years DEFENDER 90 TDCI XS,
20th Feb 2017 7:56pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 242 |
I sanded mine down and repainted myself with a spray can and lacquer. Look gorgeous! 1953 80"
1987 mini city e 2011 90" |
20th Feb 2017 11:01pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 719 |
Thanks for your help and advice. Will probably order up a pair of Landrover blocks and paint to match. The left over paint will come in for stone chips etc. Time will tell how good my paint skills are
21st Feb 2017 10:15am |
