Home > In Car Electronics > Indicator problem 200Tdi
Scott_Landy
United Kingdom 1993 Defender 110 200 Tdi CSW Firenze Red
Near side indicators front and rear have packed up! But oddly the side one in the wing is fine. Just front and rear. Recently replaced the rear indicator unit when that had packed up (bulb wasn't secure) and that fixed the rear problem. But a few days later I lost front and rear indicators. Relay at double speed as you might expect when indicate left. All other lights are good. Any idea of what might be the issue? it's on a 1993 110 so a bit interesting at times. I've put a pic below of the wiring in the rear near side corner. Have one mystery wire but don't think that was connected before. All help greatfully received!
Post #603037 19th Feb 2017 3:53pm
dorsetsmith
Post #603045 19th Feb 2017 4:11pm
dorsetsmith
mystery wire if its red/yellow wire its rear fog light
indicator LH side green/ red, RH side Green/ white and black to neg
green / Purple stop light
red / black LH side tail/ side light red/ orange RH side tail / side light
All other lights are good. have you checked lamp holder
Post #603046 19th Feb 2017 4:17pm
Scott_Landy
Thanks for that. I'll give the lamp holder another check. It's brand new but you never know. I'm working on the assumption it's most likely the rear as that is where the changes have been made.
Post #603063 19th Feb 2017 5:07pm
grafty99
It could be the bulbs, my dad recently lost both headlight bulbs on his motorbike at exactly the same time. Luckily they were H4 so he flicked the loading lever and set the rear suspension to max height to ride home on main beam. So don't rule them out Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #603074 19th Feb 2017 5:47pm
