Home > Technical > Rear shock absorber removal.
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I'm afraid this will seem like a VERY basic question but...
I need to change the rear shock absorber rubber bushes. My question is, do I need to "decompress " the shocks, i.e. Have the rear axle hang free by supporting the chassis, or can I take them off whilst supporting the vehicle by axle stands under the rear axle.
If I do have to support the chassis where is the best place to support it? Can I support it under the rear cross member?
Thanks,
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #602573 17th Feb 2017 1:39pm
Retroanaconda
No, just remove the wheel for access and there'll be plenty of room with the axle on a suitable stand. If the shock is gas-filled then it will try to extend once removed, so it'll need to be compressed down again to re-fit but this isn't difficult.
Lower nuts can be fun to undo if they've been on a while, I've had to cut them off before.
Post #602575 17th Feb 2017 1:47pm
ChrisCM
Thanks for that, they are the standard shocks, not sure if gas filled.
Hopefully the nuts will be ok 😳
Post #602578 17th Feb 2017 2:11pm
You can do them in situ, no jack or anything at all. You can compress them by hand.
Bear in mind as I'm sure you are aware that there are torque figures for all of these findings.
Bets replaced with new once removed ideally too. Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~
I got’ love for Britain, I got’ British pride’. 🇬🇧
Post #602612 17th Feb 2017 5:08pm
Screbble
This might also prove useful...
http://www.defender2.net/forum/topic40334.html
Best of luck Thumbs Up
Post #602615 17th Feb 2017 5:17pm
ChrisCM
Thanks for the info guys.
Post #602798 18th Feb 2017 2:32pm
MartinK
and here http://www.defender2.net/forum/topic13312.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #603524 21st Feb 2017 10:05am
