Home > Td5 > TD5 front diff - play in drive flange |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4390 |
Hi and welcome to the TD5 110 CSW club
By chance is the ticking worse at full lock L or R?? |
16th Feb 2017 10:17pm |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 |
Thanks. It does seem worse on left hand tight bends
16th Feb 2017 10:18pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7682 |
does the noise stop if you push the brake pedal lightly? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
16th Feb 2017 10:54pm |
Yes, and if I lift off the accelerator
16th Feb 2017 11:32pm |
Ok. So possibly the diff flange or one of the CV Joints.
Check whether the noise is coming from the left or right hand side by finding a quiet car park and driving around a friend. First one way then the other. They should listen for which side has the louder clicking or rattling. Following on from JSTs suggestion... Next thing to do is wheels straight ahead (this removes the CV joint from the equation), jack the front wheels up in turn, sit down on the ground with your legs left and right of the wheel. What you are looking for is play or wear in the wheel bearings. First, rotate the wheel and listen for clicking or rumbling, does the wheel rotate smoothly? A good wheel will rotate smoothly with some resistance. It should not feel harsh or like ball bearings being run over a washboard under your hand. Dry and rumbly. If this is the case then your bearings need replacing. Best to do both wheels at the same time. Second, grab the top and bottom of the wheel and try to rock it towards and away from the chassis. Listen for a "duh duh" sound, might be only slight, but the wheel shouldn't rock very much in this plain if at all. If it does rock but the first test was good then your bearings need adjusting and possibly replacing if on inspection they are very worn. Good luck. |
17th Feb 2017 11:10am |
Thanks very much for the info. Will be spending some time on it tomorrow so I will let you know what I find.
18th Feb 2017 10:52pm |
I've finally had chance to get under the defender and run through all the checks you have suggested.
There is a small amount of play at the back of the front diff, where the prop shaft connects. The is no play in the prop shaft, wheels, bearings or anywhere else I can find. I can replicate the noise I hear when driving by shaking the front of the prop shaft. Is it easy enough to change the drive flange with the diff on the axle or am I going to have to strip the whole diff down? Think I need to find a workshop manual! |
28th Feb 2017 12:50pm |
