Home > Technical > are early TD5 and 300 TDI bulkheads identical. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
If not identical they are certainly interchangeable Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
16th Feb 2017 7:06am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6026 |
On the under bonnet side some of the brackets are different, as the Tdi uses a different header tank to the Td5 (Td5 sits on 3 legs and mounts onto the bulkhead, whereas the Tdi is on the front corner of the wing)
Plus the clips for the front wing wiring loom plugs (although it may only be late Td5 that had these on plugs, I think early Td5 the wing looms were all part of the main dash harness?) and a few studs for earth joints and for mounting other loom fixings onto. But as JST says, pretty much similar and certainly interchangeable. Last edited by diesel_jim on 16th Feb 2017 1:59pm. Edited 1 time in total |
16th Feb 2017 7:35am |
rodspink Member Since: 12 Apr 2015 Location: Aberdeenshire Posts: 187 |
Excellent. Thanks.
This means I can extend my search area for a new one. Regards. Rod |
16th Feb 2017 12:42pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
The 300tdi wiring loom goes through the bulkhead via a round hole above the fusebox, whereas the TD5 uses the two oval holes at dash level. SO a hole will need to be drilled into the Td5 bulkhead to do this.
http://forums.lr4x4.com/topic/38064-galvanised-bulkhead-pointers/ |
16th Feb 2017 6:46pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2637 |
As JST says, they are interchangeable. I had an 86 Defender 90. Started life as a 2 1/4 petrol, then 3.5 V8, 3.9V8 and finally I fitted a 200TDI. After that I went in for a major rebuild. Fitted a genuine TD5 bulkhead. The top rail of the dash is different, so I cut the old rail off the top of the old BH and bolted it to the TD5. Also the the tunnel is different but you can buy/bolt on the specific tunnel adaptor from your current BH. The wiring loom was long enough to fit through the newer holes, just need to buy the correct gromits. Also the heater matrix mounts differently, so you'll need to drill a few holes and buy a new style gasket.
If you have any questions, please shout out 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
16th Feb 2017 8:49pm |
Thats ace.
Thanks again folks. Rod |
17th Feb 2017 1:33pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1546 |
I buy my bulkheads from Robert at Mosside Land Rovers, maybe worth asking
https://m.facebook.com/mosside.rovers/?locale2=en_GB |
20th Feb 2017 12:31am |
Cool.
Thanks for that. Iv added on facebook. Cheers. |
20th Feb 2017 6:38am |
Thanks all. Got a new one in ebay and its local. Problem sorted. Although it leads to some more questions. Will start a new thread I think. Lol.
20th Feb 2017 10:39am |
