Home > Technical > Which crossmember?? |
orkneydave Member Since: 25 Sep 2016 Location: Orkney Islands Posts: 76 |
My son has recently discovered that his gearbox crossmember is made of hammerite and sand!!
Its a 1986 ex MOD 110 (formerly soft top) that came with a 19J but he has recently fitted a 300tdi. I have found various listings for replacement crossmembers but none for a 110 so early. Any ideas? I also guess the chassis rails where the crossmember touches will be a touch tender too! |
13th Feb 2017 10:34pm |
Thanks James, that's what I thought but was starting to doubt myself.
14th Feb 2017 8:56am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2639 |
I'm sure I have a flat style crossmember in the back of the garage somewhere if needed 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
14th Feb 2017 12:32pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
Is he using the LT77 gearbox still? Round and square type including td5/ Tdci are nearly all the same, only bit is a Tdci has that stupid mount for absolutely no reason in the middle of it, which 2 minutes with a grinder will fix, tend to find these come up a bit cheaper. If he's fitting the R380 box you can use the 300Tdi discovery crossmember with a little bit of trimming too, either on the crossmember itself or the seat box "saddles" that the front M6 bolts fit through.
20th Feb 2017 1:44am |
Thanks for all the replies
Yes he's still using the LT77 box. I did suggest he used the R380 but he seems happy with what hes got, although he may change the transfer box shortly. Walfy, if you have a crossmember spare that would be great. I'll send you a PM. |
23rd Feb 2017 6:03pm |
