Home > Technical > TC light comes on when driving,especially when changing gear |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 287 |
Had a similar issue on my works 57 110. Fortunately the garage managed to sort it by changing the brake fluid and it hasn't come on randomly since. They said that the abs modulator have a habit of playing up. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
12th Feb 2017 7:19pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
Mine does this when you turn hard left on cold mornings & sounds like the front drivers calliper coming on or a noise like AH AH AH
Maybe its time for a brake fluid change as I do need to change my rear pads Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
12th Feb 2017 9:44pm |
A worn wheel bearing can sometimes cause this to happen. Darren
12th Feb 2017 10:19pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2586 |
or dirty ABS sensors --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
13th Feb 2017 9:07am |
explore Member Since: 02 Dec 2011 Location: Crewe, Cheshire Posts: 34 |
Try pushing the front ABS sensors in slightly
13th Feb 2017 10:48pm |
