Home > Puma (Tdci) > No fuel in fuel rail 2.2 Puma
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
Car: Defender 130 2.2 MY12
Still struggling to start my car.
There is no fuel in the fuel rail when I push the green valve. I have a new vcv on the bench. But I cannot believe it is the cause no fuel at al is in the rail.
The fuel pressure on the faultmate is reading o psi.
Am I correct that there is a fuel pump in te tank?
If so, is it there only to prime the lines as the mechanical pump on the engine is there too? (So no bleeding of the lines after for instance a fuel filter chang is Nessisary ?
Am I right that if there is an electric fuel pump, that is working, at least fuel should poor out of the green valve at a low pressure?
Any help appreciated
Post #600877 11th Feb 2017 8:23am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Sorry, I can't not answer but very interested with this.
It is not verry clear how it wortks ...
So complicated
My defender is also 2.2 my2012 ...
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #601329 12th Feb 2017 9:34pm
