Home > Td5 > Can it be done? Bezel Louvre side air vents on a TD5 |
bogwert Member Since: 03 Sep 2016 Location: Dundee Posts: 194 |
Its the time of year again when driving anywhere the side windows mist up and you can see ... nowt! Arguably in Scotland that time is between Late August and early June.
My idea is (without spending £100+ on vents) to fit Bezel Louvre vents off a Puma to the sides? Surely someone has tried this...? My thoughts are, take off the dash, fit in a bit of conduit pipe to the main windscreen blowers, divert it along to the side, drill a... probably square hole, and attached a Bezel vent? Can it be done? or why can't it be done? Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW |
9th Feb 2017 2:30pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4392 |
I have not seen those vents being used, but I do remember someone DIYing vents with bulkhead fixings and ducting...
Probably on here... |
9th Feb 2017 3:56pm |
This is Retroannocondas take on the mod
http://www.retroanaconda.com/landrover/201...demisters/ But it is not the one I remember. |
9th Feb 2017 3:58pm |
Another version from this forum;
http://www.defender2.net/forum/topic33126.html But still not the one I remember |
9th Feb 2017 4:01pm |
9th Feb 2017 5:23pm |
Could work, it just depends on the dimensions of the puma vents 2002 90 Td5 Station Wagon
9th Feb 2017 5:57pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
think you will find you will be very limited by using those vents. The heater controls at the driver's end don't leave much room for a duct/vent to pass through.
Passenger side the rubber handle only has a small area too. The defenderdemister kits have possibly the largest round vents you could easily fit with the convoluted tubing. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
9th Feb 2017 6:15pm |
9th Feb 2017 7:20pm |
They're definately bigger than 20mm. More like 40 - 45mm 2002 90 Td5 Station Wagon
9th Feb 2017 7:30pm |
But I don't know for sure, maybe someone with a puma could pop out with a tape 2002 90 Td5 Station Wagon
9th Feb 2017 7:32pm |
9th Feb 2017 7:34pm |
Funnily enough this exact same mod went through my head a couple of days ago
I'm planning on implementing it slightly differently. I'm going to feed air into the top of the door card via a sealed duct. When the doors are shut air will pass into the door card and then escape between the top of the door card and glass which should hopefully demist the whole window. I'm also planning a fan upgrade for more airflow 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
9th Feb 2017 7:43pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
I can go out and measure if there is still a need?
9th Feb 2017 8:43pm |
Oooo what you thinking? Secondary inline fan motor or replace the existing one? |
9th Feb 2017 9:29pm |
