Home > Technical > 2015 TDCI Horn Connector |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
Derek - don't know if I am helpful here. Had an air horn installed - in the kit there was a switch - so that you could switch between normal horn and air horn. Auto electronics not my strong point - so I had a technician and fellow Defender club member install it.
8th Feb 2017 6:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19574 |
Photo would be useful. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
8th Feb 2017 7:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16877 |
I think that they are standard 2-pin Econoseal connectors.
8th Feb 2017 7:14pm |
DerekV Member Since: 12 Oct 2015 Location: Surrey Posts: 39 |
Thanks for your replies everyone!!
Here's a photo of the connector. Sorry it's not the greatest but it's pretty awkward to get at!! I've just noticed that there seems to be a number on the back - 985324-1 - and Googling it brings up an Italian eBay listing for a similar looking connector, so that may be it, but if so I'm not sure I'm going to be able to get hold of one in the UK. Assuming I'm not able to get one, does anyone know what size wire (mm2) is used for the horn, as I'll probably have to use a Posi-Tap connector but they're pretty specific with their sizing! Thanks. Derek. |
8th Feb 2017 7:36pm |
That's an AMP connector used inter alia on BMWs. Definitely not the Econoseal I thought it was sorry! Also (I think) used on Disco 2 horns.
Edit: update - just for the record, Disco2 horns and Defender horns have totally different connectors and are not directly interchangeable. Last edited by blackwolf on 25th Feb 2017 3:10pm. Edited 1 time in total |
8th Feb 2017 7:52pm |
Ah right, thanks blackwolf. Do you know where I could try to get one of those (and the male half) in the UK (Google turns up nothing), and also do you know if an econoseal crimper would work to crimp the terminals?
Also, do you know what wire size is used on the horn? Thanks. Derek. |
8th Feb 2017 8:17pm |
Offhand I'm afraid not, but I have a spare wing harness somewhere. If I can find it I might be able to figure out the wire size. It is unlikely that the crimps will be too specialised and I imagine an Econoseal type tool will do the job.
8th Feb 2017 11:22pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
According to the electrical reference manual C003 and C004 are MQS series, LR part number YPC110600, wire is size 0.75 and terminals are LR part number YPL101510 if that is any use?
(doesn't directly help with the mating connector, but it might be a start) |
8th Feb 2017 11:45pm |
Thanks blackwolf and apt100! That's really useful info. Just need to find a mating connector now and I'll be sorted! If I can't find one I'll just use the posi tap now I know what the wire size is.
Thanks again for your help everyone! Derek. |
8th Feb 2017 11:58pm |
https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171
BTW I got the documents from here if you are interested - helpfully posted by a member on previous threads |
9th Feb 2017 12:12am |
Just a correction - the number written on the connector was actually 965324-1, not 985324-1!! I think I'll try writing to a shop that sells these connectors to see if they can suggest a mating one.
Derek. |
9th Feb 2017 12:13am |
Ah wow, that's incredibly useful, I've been looking for a workshop manual for ages!! Thanks! |
9th Feb 2017 1:19am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6480 |
I can supply a mating connector for these, drop me a PM 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Feb 2017 6:30pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
Any Durite supplier should be able to get them, or Paul at LRconnectors is an absolute gent and a legend for this stuff.
20th Feb 2017 1:47am |
