Home > Td5 > Fan - all or nothing |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1038 |
Well you have seen up in my other post, but in standard form, the lever on the left has a 2 speed fan switch incorporated. Speed one is like a gnat farting though the vents, speed 2 is like Sir Alex Ferguson in a bad mood! As you move the lever up to the top it closes the fresh air flap completely.
With the Landrezieger mod, the air flap cable is left disconnected in the open position, and the complex switch lever assembly is replaced by a simple variable resistor, which talks to a PWM controller that sits under the bonnet, and controls the fan. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
7th Feb 2017 10:44pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
Yep I understand the benefit of the mod I am just wondering if I should have had more than the one setting in the first place
7th Feb 2017 10:52pm |
There are 4 settings in total.
1) fan off fresh air flap closed 2) fan off fresh air flap open 3) fan low speed 4) fan high speed 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
7th Feb 2017 11:52pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Really?
Mine, and other defenders I know, have only 3 detented positions on the handle. Off (and closed) Low speed High speed |
8th Feb 2017 12:11am |
Mine has closed and off right at the top. Then move it down and the flap opens before the first speed. Then down to first speed and full speed etc. That is how it should work if the cable is correctly adjusted 2002 90 Td5 Station Wagon
8th Feb 2017 12:17am |
AndyB Member Since: 10 Nov 2016 Location: North Wales Posts: 37 |
Just had a look on eBay
http://www.ebay.co.uk/itm/60A-DC-Brushed-M...SwjDZYd-5t What is your opinion on trying something like this? Seeing as we have a 'rather older' 90, the control knob would not look out of place sticking out of our dash! Andy |
8th Feb 2017 9:54am |
It's worth a go, but I wanted to keep mine looking as standard as possible. You would have to make your own wiring up with this I presume? 2021 Defender 110 X-Dynamic HSE D300 MHEV
8th Feb 2017 10:13am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
My 90 was
Off Low High My 110 XS seems to be Off Very low - If I leave it inbetween low and off, probably a fault but its quite nice Low High |
8th Feb 2017 12:12pm |
Ah ha I have figured out that I am missing the high mode so I guess it is time to adjust the cable !
8th Feb 2017 2:46pm |
The cable only controls the flow of fresh air into the heater system. If you have only one fan speed it will be either the dash switch or the wiring at fault 2002 90 Td5 Station Wagon
8th Feb 2017 5:31pm |
