Home > Technical > Indicator relay |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
Did you check behind dash?
7th Feb 2017 7:40pm |
Jon110 Member Since: 26 Mar 2016 Location: Newcastle under lyme Posts: 83 |
I didn't
I removed the panel by the gear stick . Thought it would be one of the 6 relays there The instructions or any of the other threads never mentioned that |
7th Feb 2017 7:44pm |
Found the answer
So much for the instruction sheet. |
7th Feb 2017 8:29pm |
Spill...for other members?!
7th Feb 2017 8:31pm |
As you said behind dash for my2002 onwards.
Will look tomorrow and see if the information I found is correct |
7th Feb 2017 8:34pm |
7th Feb 2017 8:52pm |
Brendlynch Member Since: 06 Nov 2016 Location: Grouville Posts: 182 |
Out of interest did you use the wipac ones and was the relay you swapped out the 4th one along from the right?
28th Jan 2018 4:40pm |
