Home > Technical > suspension setup for my 300 TDI |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 809 |
On the TD5 90 Hard top we run standard LR defender 90 springs on the front with LR police spec range rover springs on the rear, standard anti roll bars, with Boge shox all round.
Won't break the bank and makes a big difference to the ride of a 90 as its empty most of the time, but i wouldn't recommend this set up for towing. Have always found the Terrafirma shox a tad too hard N. |
6th Feb 2017 8:18pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
cheers nidge, I did go for my dads setup in the end, but I will be fitting anti roll bars. ( well front one until I find someone to weld the rear plates on)
I have also bought poly bushes too, so when I swop the dampers and springs over, those are changed too. My dad ended up having to swop his to poly bushes. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
12th Feb 2017 2:34am |
It depends what you want to do with your 90. This is my td5:
Click image to enlarge So it's a bit heavier and I use it heavy off-road. The standard springs are to light for me so I have now rear springs 275lbs/inch? front and 350 lbs/inch rear. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
12th Feb 2017 9:58pm |
