Home > Technical > Help - Can't lock my Defender - Puma 2012
meneguelli
Brazil
Hello,
My name is Pedro!
I have a Defender 90 from 2012. The problem began when I tried to change the key fob's battery. I did it without reading the manual, so after I changed it, the car would't start. I took it to the dealer, and its alive again now. But the problem now is that I can't lock the car, neither with the key or with the fob.
I would love some help with this matter. I'm a newbie in the the Defender world...
Thank you very much
Post #598955 3rd Feb 2017 11:08pm
ickle
I think the dealer has changed some of the settings on the ecu, take it back and make sure it's been programmed properly.
Good luck
Keith
Post #598963 3rd Feb 2017 11:49pm
mk1collector
Why can't you lock with the key? What happens? Ray
My build thread
Post #598965 3rd Feb 2017 11:53pm
meneguelli
Brazil
When I turn the key to lock the door, it locks and then the latch goes back to the open position. It happens even if I hold the key turned in the lock position.
Post #598977 4th Feb 2017 12:52am
