Home > Tdi > Magical figure. milage, |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
That's it. 300 tdi next, for me. |
30th Jan 2017 12:06am |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
Still on the original injection pump,. av full service history ,and all the M.OT."s. and every tax disc,, , gearbox,[ broke layshaft lost 5th & reverse, still drove it home ] . shifted transferbox, [ worn flange housing] front props do 20,000 miles, rear props do 50,000, miles,
water pumps = go for bearmach or O,E,M]. as The £15 ebay items do 10.000mls only, did the P gasket . shifted the original starter @ 280.000mls , its on its 3 rd vac pump. and new clutch, [ clutch rod went thru release arm, @ 140.000mls] so did clutch while there, |
30th Jan 2017 12:39am |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 746 |
My 300tdi has 200k to go to get to that figure Looks like I should be able to look forward to many more years of tinkering. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
30th Jan 2017 9:48am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10502 |
Hi Blackhat90, is that all the 3's =333,333 ? if so i'm only 33,000 behind you
I cant see the middle 33 for the flash 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
30th Jan 2017 10:32pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
I am 50000 in front of you ... (300 Tdi, 21 years old). Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
30th Jan 2017 10:37pm |
Yip. its all the 3"s, And veetee " 380,000. that amazing, mine is on the road every day, [ work horse,] I worked out, I"l be retired when the digits line up for the 4"th time, and probably wont see 555555. |
30th Jan 2017 11:47pm |
Mine to is a work horse and on the road most days to 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
30th Jan 2017 11:51pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Blackhat, VT is more then likely 'cheating' as far as the UK members are concerned.
He will be using those new fangled EU units inflicted on the rest of Europe by Brussels know as kilometres They use a smaller unit of distance so that the distance seems greater with a bigger number. 380,000 km is about 245,000 miles. Our red 110 96 model bought in 97 has about 212,000 miles on with about 2/3rds of that mileage done abroad. Recently had to have a new alternator fitted as it stalled the engine! Brendan |
8th Feb 2017 10:06am |
Ha Brendan , that makes sense, coz I"v never seen or heard of a higher milage defender / disco.
V/t"s is bearly run in , |
8th Feb 2017 4:55pm |
Haha, well you have a point there
I'll try and do my best to get the equivalent of 380000 km in miles on it, but to get to that won't be easy at my age... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
8th Feb 2017 5:01pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2548 |
I know of one 200Tdi well above 400k for sure, and have heard second hand about several Tdis over 500k but not seem them myself. Mine is only on 283k so 50k behind yours. Should hit 300k around June/July time at current annual mileage. Only downside of a Td5 instrument pack - I don't get to watch the numbers all turn round on big ones any more! |
8th Feb 2017 9:03pm |
400.000 truly amazing . and 500k, wow, just shows you ,good clean Oil and filters do the trick , I change every 5000mls, my Turbo is still original, I"v seen Disco"s blow turbo"s at 120.000 , is this due to lack of servicing ,/
8th Feb 2017 11:42pm |
Very much so due to the lack of servicing as mine is serviced every 6000 miles and as yours, mine is still the original turbo
Those mileage numbers are amazing and something to go for 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
8th Feb 2017 11:47pm |
