Home > Technical > shirefabrications pedal lock |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7681 |
http://www.shirefabrications.com/shop.html
anyone using one of these or found a better solution for mechanical security on a puma? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
29th Jan 2017 1:37pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
Yep I use one on the 90 td5 version covers pedals well good and solid like it.
29th Jan 2017 2:02pm |
so those that have, would you buy same again? Cheers
29th Jan 2017 2:17pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3333 |
I use one along with a disklock as well. Belt and braces.
In answer to your question, yes I would buy one again (though it will probably last longer than the Defender!). Hard to say how effective it is as luckily I have never had it or the truck tampered with. It's a bit awkward to get on at first, but with a bit of practice, it gets quicker. It's a pain in the arse when it's raining. As Froglaise says, it's a hell of a lump and mine is connected to a pvc protected chain and caribeaner which in turn is through one of the lashing eyes in the back of my USW when being driven. Plenty of posts on here about these things flying around in the event of an accident. |
29th Jan 2017 3:04pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1523 |
i tried one but have swapped to using ardcase ones as they are smaller and easier to store when not in use.
29th Jan 2017 3:08pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
similar...
http://adrenalin4x4.co.uk/index.php?route=...97_298_331 One of the most popular pedal locks (not mentioned) on the market uses a very poor lock. Just a simple cheap lock welded on from your local general store. Check out the actual locks themselves on the product, talk to the makers, some of the locks themselves cost the company a hefty percentage of the purchase price! |
have seen the lock on its, believe that is workable Cheers
29th Jan 2017 3:46pm |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 |
Hopefully would not have too, but yes. |
29th Jan 2017 3:50pm |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 295 |
Yep I have one on my puma and although it is heavy and awkward, its ideal for purpose and well made. North Cumbria Search and Rescue - Team Leader
29th Jan 2017 4:00pm |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 |
Hi.
I use a Shire pedal lock on a TD5. My method is the Shire lock is kept at home , fitted every evening, along with a X engineering twistlock thingy on the gear stick.( plus other things) which is kept with the truck at all times and fitted when ever the truck is left unattended, no matter even if its popping into a shop for a quick purchase. The Shire fab pedal lock is cumbersome and really do not want it flying about in the case of an incident. I like it and its well made, thought the paint is continually flaking off. it easy to fit once you get the knack.. |
29th Jan 2017 7:26pm |
Zag, and why not mention it? No reason not to do that I think. Correct me if I'm wrong, but I think you mean the Ardcase. I have one, and its ancient large type of simple key/key blade is not a thing of todays world anymore. Laughable actually. I do like the practicality and the general built quality of the Ardcase, but as for the lock itself I can only hope that when the Ardcase is placed and locked over the pedals, it is in a rather awkward position to allow a potential thief who is in a rush to quickly pick its lock. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
29th Jan 2017 7:57pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2024 |
I have the Shire Fabrications Safe T Pedal on my TD5 in addition to other layers.
I'd buy the same again without hesitation. Heavy and cumbersome, yes, but you get used to it and after a big of practice you can fit it with one hand in quite a slick single movement. I fit it even when popping into shops etc. Can't imagine it being easy to remove without the keys. And with my preferred safe storage position in the rear, it's also perfect for keeping two 2 litre milk cartons upright and secure on the way back from the shop! |
30th Jan 2017 11:38pm |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 323 |
Ooooh and it comes in pink too!!! Defender 130 HCPU Td5 MY2000
31st Jan 2017 1:11pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
As above really... I have a Safe-T-Pedal, (Angry Puma discount for £95 delivered). It is very heavy and cumbersome but once you have the knack is pretty easy to put on and off. It seems very robust and I've never seen mention of anyone having had it removed/defeated (unlike the Ardcase). Storage was very awkward until I fitted some seat rise, now tucks nicely under the middle row seats.
If I bought one again, I might consider the Ardcase, just becasue it is smaller to store and lighter to use, but is more expensive. Even though there are photos of one being removed it must still be a deterrent. Or the X-Eng hinged locking plate, if they make one for a Puma? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
31st Jan 2017 3:03pm |
