Home > Td5 > Propshaft's 2005 TD5 Alignment |
randallised Member Since: 30 Apr 2012 Location: Doolin Posts: 18 |
Howdy , just replaced the clutch, flywheel etc and forgot to mark the shafts. The front prop seems to be off set (30 Degrees) at the UJ's so the two ends do not line up when on the floor ? Is this the way the front is supposed to be ? Would the two ends not be fighting each other ? The rear looks right.
Any help much appreciated |
27th Jan 2017 10:06pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2548 |
Front prop should be slightly out of phase. Rear prop should be in phase.
Due to different planar alignment of front diff and transfer case flanges. |
27th Jan 2017 11:04pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
What he said! ^^^^ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
28th Jan 2017 11:14am |
Thanks all very much, appreciated.
28th Jan 2017 11:51pm |
