Home > Td5 > Is something missing from my Defender? |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1038 |
If I look under the rear right hand wheel arch, and look at the back, I can see all the pipe work for the fuel filler, and a lot of wiring to do with the tow electrics is exposed. Is there supposed to be a cover for all this? As it exposed to the full force of any mud and water coming off the rear wheel.
I only spotted it today as I was jet washing the underside to get the salt off. Can get a photo tomorrow if it helps. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
27th Jan 2017 6:18pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
There should be a plastic guard to cover the rear panel and wiring
27th Jan 2017 6:20pm |
Thought so
Does anyone have a part number? 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
27th Jan 2017 6:22pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2238 |
http://www.ebay.co.uk/itm/371338060572
These should do the job. |
27th Jan 2017 10:49pm |
They're them alright
27th Jan 2017 10:57pm |
Thanks, it's to keep the wiring dry. I can always remove it for proper cleaning. Rear crossmember is going to need replacing soon anyway. 2021 Defender 110 X-Dynamic HSE D300 MHEV
28th Jan 2017 6:50pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Neither of my landys (02 90 CSW, 04 110 XS) had any shielding there! I wouldn't worry about it getting wet, its generally all pretty waterproof.
2nd Feb 2017 4:25pm |
