Home > Td5 > Thermostat |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I think it's something they all do. the engine doesn't give out enough heat so the heater just cools it down.
Every rev it a bit when it cools or fit a rad muff. I'm running around with a radiator muff/cover at the minute 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
23rd Jan 2017 2:12pm |
To combat this I removed my viscous fan. Have had it removed for nearly 2 years now and not the slightest hint of overheating. If you are worried about it you could just remove it for the winter
Even with a rad muff if you still have the fan it still draws cold air in 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
23rd Jan 2017 2:35pm |
Also check if you have the fuel cooler coolant restrictor installed 2002 90 Td5 Station Wagon
23rd Jan 2017 2:36pm |
I had an off-road event last weekend and had the same. When idling for a while the gauge showed cold but I still got warm air from the heater. Looking at my nanocom the Coolant temp was still somewhere in the 60 C area, so it's not that it gets really cold. Roel
25th Jan 2017 8:01am |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
It is strange though as I thought that the thermostat bypasses The radiator when cold in order to keep things at the corrrect working temperature. Surely you should not need to remove the fan and cover the rad of there is nothing flowing through it?
25th Jan 2017 12:09pm |
The fan will still be blowing cold air across the engine block and also if the ambient temperature is low it will help cool the engine internally as it is drawn in. Although the effects of these are small - on an engine that already produces little heat it will have a noticeable effect! 2002 90 Td5 Station Wagon
25th Jan 2017 2:22pm |
I think most off the heat is going to your heater to try to warm the interior up. Roel
25th Jan 2017 2:27pm |
Yes hadn't thought of that - definitely going to take some heat out 2002 90 Td5 Station Wagon
25th Jan 2017 2:44pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4395 |
It would be worth checking your viscous fan is in good order. If it seizes in the locked position it will obviously suck more cold air through your rad.
The other thing I have seen is someone fitting an auxilary pump in the coolant system to assist the standard pump whilst sitting in traffic. The idea was that the engine was still hot enough but the coolant flowing through the heater matrix wasn't moving fast enough to heat the incoming air. I cannot however remember if the system worked, but it is a good solution. Heated seats make life a little more comfortable, easy mod too. After that it is time to think about an auxilary diesel heater. |
25th Jan 2017 4:42pm |
yep makes sense it was -4 ! I think I will fit a rad muff and my heated seat kit when I get a moment.
25th Jan 2017 10:10pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I need to fit a rad muff to mine, just doesn't get that hot in the winter!
Not going to remove the fan as I do use it for a fair bit of heavy towing. |
25th Jan 2017 10:17pm |
I can thoroughly recommend this one, the Combo Cover, made by a small company called GlobeRoamer:
Click image to enlarge This is the second one I've had and is a refinement on the original design. It can be opened to any degree by way of two zips. Also available in canvas. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
25th Jan 2017 10:25pm |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 |
Same problem - so viscous fan removed and twin electric fans fitted to an XEng X-Fan Thermostatic Fan Switch; Rad Muff fitted and also changed the cap on the header tank as pressure wasn't being held as much as it should and replaced the thermostat. Adventure isn't paved!
27th Jan 2017 8:11pm |
