Home > In Car Electronics > Discreet reverse camera screen |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10476 |
Do you mean this one
Click image to enlarge 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
23rd Jan 2017 11:14pm |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
Not that one unfortunately. It was mounted flat onto the heater blower panel on a puma.
But thanks for playing |
24th Jan 2017 10:24am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
Hello
Why do you need to get at the menu? I've tried two types now, a flip up one and flat one with as you say the menu buttons on the rear. I've never used them? Once in place it works no need unless you have two cameras and want to go to AV1 or AV2? |
24th Jan 2017 10:33am |
I've no idea if I need to get at the menu buttons or not. But if I glue the monitor in place I won't ever be able to get at them. Not even sure what they do tbh. I'm after just a very simple display, single input for reverse camera only. Just want it tucked out of the way.
24th Jan 2017 11:01am |
The one I have does very little on the menus
Swap between 2 inputs. brightness, contrast, 16:9 or 4:3 I have never changed them and doubt you would ever so would think any would do? |
24th Jan 2017 11:21am |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 573 |
You could go down the rear view mirror integrated route or fit it to the sun visor?
Otherwise,go all in and go double din. |
26th Jan 2017 11:08am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19532 |
Ifor Williams do a stand alone one, or you could go the routes suggested. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
26th Jan 2017 12:04pm |
No interest in a double din unit. Waste of money.
I've tried the mirror with integrated screen. Was sent back after a few days. The mirror only works properly in certain light conditions. I'm going to just get a basic one like suggested earlier and hope I won't need to use the menu buttons. |
26th Jan 2017 12:17pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
It is a problem in the Puma due to the lack of anywhere readily available for the screen.
I don't want a rear view mirror solution, because I don't have an interior RVM! I don't want to go double din (way too expensive and too much hassle just for a screen). Has anyone had any experiences, good or bad, with single din flip screen units? I notice that several of these have camera inputs and thought that that might be an option. |
26th Jan 2017 1:21pm |
As you haven't got a rear view mirror, is that not the ideal place to mount a screen instead? Darren
26th Jan 2017 2:09pm |
Yes bad, I had one and sent it back because it covered way to many switches and with the loom on the back it was very tight to fit all the wiring in (Td5 admittedly) Couldn't reach hazard rear and front heated screen and rear windscreen wiper and wash in mine 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Jan 2017 2:21pm |
That is exactly what is putting me off trying one - I couldn't reach the switch for the hazards, more importantly I couldn't reach the switches for the heated front screen and battery of all-round scene-lighting.
I could mount a sceen above the centre panel of the dash but that would obscure the clock. Guess I'll just continue to live without a reversing camera! |
26th Jan 2017 2:41pm |
An interesting idea, though it would have to be a fairly teeny screen. I will investigate. |
26th Jan 2017 2:43pm |
Just adjust the screen out so there is room behind.
Have it set manually so you can open and close it when you like. Not used mine in ages, it's playing up. 1 DIN or 2 it's all gone way way to expensive to be worth it now & what ever you buy will be out of date in a couple of years. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
26th Jan 2017 2:44pm |
