Home > Td5 > New Owner and first breakdown :D |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6460 |
Your fuel pump sounds noisy, like there is air in the fuel system which has not purged out. Has it always made the same noise or is it only since you've disturbed things? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
27th Jan 2017 12:06am |
Cactus79 Member Since: 09 Jan 2017 Location: Cheshire Posts: 51 |
I'm not sure that I had left the pump running on its purge cycle long enough in that video. I have subsequently run 2 full purges and it does seem quieter but I'll do another video later as being new to TD5's I don't know what normal is yet. (Hoping for less fixing and more modding mind)
Will check the injector again for its connections and for any cracks in the head as I don't fully understand if the injector is putting more fuel in because there is something else wrong like an air leak or problems in the engine loom or just a dodgy injector. Thanks for all the suggestions |
27th Jan 2017 7:54am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 556 |
First think for good run of TD5 is perfect electrical connection between engine ECU and injectors. Injectors are controlled from ECU by pulse voltage - something like 90V and 50A - so any bad connection means not proper injector control. Check all connector between ECU and injectors - description with details is in RAVE. Fault in TD5 injector is uncommon, electrical fault in wiring on of TD5 standard problems, masked by oil in loom. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
27th Jan 2017 8:37am |
Replaced injector, recoded the ecu.
Fired it up and were back on 5 cylinders but it's still smoking it's bag off. Engine feels fine, turbo pickup is good, injector balance is within tolerance, but still very much a diesel stinging smoke. Time for a brew. |
27th Jan 2017 11:50am |
So,
Had all the injectors back out, looks like number 4 had an issue sealing due to carbon deposits. Cleaned each bore and made sure each injector was as clean as can be and put everything back. Car still smoked, took it down the road and still smoking. Took fuel filter off as i've bought a service kit for the Defender. Checked the valve from the fuel filter housing which all looked fine, didn't fully pull the valve out of the casing mind. Put new Mahle filter back on, primed the system and started it up and NO smoke. Been down the road again but losing too much light but very little smoke on acceleration in peoples headlights. Not convinced it's fully fixed but probably because i don't understand why, best guess blockage in the fuel filter or valve which increases the return pressure or am i just going mad? |
27th Jan 2017 5:36pm |
So started the car this morning and it was a little smokey but miles better. Ran a purge on the fuel system, not much change. Went to take it down the road to find the clutch wouldn't engage.
So bonnet up, axle stands out, clutch bled obviously hasn't been done in ages given the colour. Changed the oil, sump plug has been mullered and put on with an impact hammer given how much effort it took to take off. Swore lots of times about Landys but once started Dougal behaved. Took down the road to check it over and the smile in 3rd gear is intoxicating, remembered why we bought it in the first place. Changed the radio over to an eBay special to find someone failed to wire the previous unit in correctly, fixed the wiring and remembered to put the viscous fan back on and check the oil again. Hopefully tomorrow I can get back onto the bathroom which has been on hold for a few weekends. |
28th Jan 2017 7:33pm |
