Home > Tdi > 200TDI Lack of power and cutting out |
xcentric Member Since: 17 Jan 2016 Location: Midlands Posts: 247 |
was it cold enough for the diesel to wax up?
20th Jan 2017 10:09pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2520 |
Certainly sounds like fuel starvation. Change filter and check fuel pipes are clear and fuel is flowing.
Also check air intake pipework, could be air starvation but that generally creates a vast cloud of black smoke too which you probably would have noticed! |
21st Jan 2017 1:46pm |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 701 |
Wouldn't have thought it was cold enough for Diesel to wax up, think it was approximately -1C, but fuel filter should be warmer in the engine bay?
I changed the fuel filter this afternoon, and on the test run it seemed to be back to normal, so hopefully I will be able to consider it as an easy fix! |
21st Jan 2017 2:48pm |
