Home > Puma (Tdci) > temp gauge loss of power
mastertech
hi guys
I have a 2008 defender 90 puma
every now and again temp gauge and battery light comes on and there is a loss of power when fault is there it starts and runs
with sdd ive re configured and a software update
still faults
has anyone had this or knows a fix ??
Post #594529 19th Jan 2017 7:30pm
dorsetsmith
Engine wiring loom chaffing on metal engine block
Post #594530 19th Jan 2017 7:37pm
agentmulder
Kuwait
Assume the chaffing is upstream of the coolant temp sensor?
(which is where?) Solved the bowel problem, working on the consonants...
Post #594537 19th Jan 2017 7:50pm
mastertech
It's not a coolant sensor fault in sdd it's saying loss of can , engine relay and incompatible software
Post #594552 19th Jan 2017 9:05pm
agentmulder
Kuwait
Please ignore if you know better but it was my understanding that DTC faults cant be guaranteed to be accurate. If a system is faulty the fault codes can be just as spurious as the symptoms..
Of course, even when they're wrong, they can provide helpful hints (as often as they give you red herrings). Solved the bowel problem, working on the consonants...
Post #594554 19th Jan 2017 9:10pm
dorsetsmith
coolant sensor is wired ECM
controller area network between ecm to instrument cluster
battery light wired to instrument cluster
Post #594556 19th Jan 2017 9:12pm
mastertech
Post #594563 19th Jan 2017 9:25pm
mastertech
No I agree it is wired in the ecm
But the fault is communication to cluster via ecm
I will check loom but was kind of hoping there was a tbs or something
My apologies it posted twice am mobile at the moment
Post #594566 19th Jan 2017 9:28pm
mastertech
thank you dorsetsmith is there any particular place they chaff ?
Post #594600 19th Jan 2017 11:21pm
