Home > Technical > Led Headlight issues
ijc32
United Kingdom 1999 Defender 110 Td5 DCPU Aintree Green
Hi all
I have a set of new LED headlights but when fitted they appear to work fine until you indicate left or right, at with point the High beam illuminates on the selected side. This dose switch back to normal after a short period. Cant think why this is happening best guess is that it senses a V drop in the internal controls.
Anyone have an idea as to the problem and how to deal with it?
Thanks
Post #594334 19th Jan 2017 11:06am
Are your indicators LED or standard?
You'll likely notice a drop if you use the electric windows too. Not quite sure as to why it's a particular side though. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #594356 19th Jan 2017 12:13pm
ijc32
No indicators are standard and as far as i am aware not even on the same circuit ? But turn right = right hand high beam, same for left. ???? No power windows though she is an old bird.
Post #594388 19th Jan 2017 1:21pm
dorsetsmith
check the earth as this is common to both
Post #594390 19th Jan 2017 1:29pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
If be taking a look at the state of the earths. I can't say it is an earth problem but most problems of this type usually are so it would pay to check their security and cleanliness.
Post #594391 19th Jan 2017 1:31pm
geobloke
As above. Earths are the likely culprit. Bad earths can cause all manner of interesting light related issues. Ever followed someone that is indicating and pretty much all the lights on the back are flashing...!? Bad earths...
On my old 200tdi the only way to sort out the odd lighting issues was to rewire all the earths seperately to the chassis. Never had a problem after that.
Post #594395 19th Jan 2017 1:39pm
ijc32
Thanks for all your inputs will get the earths checked tomorrow, fun day ahead for me :0(
Post #594533 19th Jan 2017 7:42pm
