Home > Td5 > Td5 Glow plug relay - part number/llocation |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
This is the relay.
http://www.brit-car.co.uk/product.php?xProd=95302 It is under the drivers seat but not sure which one ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
17th Jan 2017 2:42pm |
one below is My 2002 and one below that is My1999 to 2001
Click image to enlarge driver seat box ( MY1999 rave ) working from foot well end first yellow relay cooling fan next one yellow relay compresses clutch A/C next one black relay Glow plugs next one black relay ABS return pump next one yellow relay ( main ) canter box fuse box ( MY1999 rave ) working from passenger side first yellow relay starter next yellow relay heated rear screen next yellow relay head lamp next brown relay sounder alarm next green relay fuel pump also ecu delay windscreen wiper unit brown / relay hazed warning black Last edited by dorsetsmith on 17th Jan 2017 6:13pm. Edited 1 time in total |
17th Jan 2017 2:52pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5740 |
Thanks chaps. Is this just a standard relay? 1999 Defender TD5 110
17th Jan 2017 3:47pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6480 |
Standard but the 70 Amp version with the fat power terminals 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Jan 2017 3:56pm |
Thanks. 1999 Defender TD5 110
17th Jan 2017 5:21pm |
By the looks of it, same one as used on a Freelander and Disco 2 1999 Defender TD5 110
17th Jan 2017 9:46pm |
It's a generic part so will be used across the LR range 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Jan 2017 10:10pm |
This part number is for a Disco 2 which apparently does not fir a Defender. The correct part number appears to be PRC6913, so will compare that to the relay in the fusebox to be sure. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
18th Jan 2017 2:37pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2198 |
I believe PRC6913 is the timer and relay for the TDi models not the TD5 which is ECU controlled and should only be a relay.
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
18th Jan 2017 2:39pm |
That was from speaking to main dealer and also Dan at Duckworths.....? Maybe because mine is a Jan/1999 model ? 1999 Defender TD5 110
18th Jan 2017 2:41pm |
Could well be, I guess the parts system classifies these as to/from VIN number so if yours is close to the cutoff there might be some confusion. PRC6913 is definitely the timer and relay for a TDi which lives under the bonnet on the bulkhead. The TD5 relay is standard size with larger terminals and is under the drivers seat.
18th Jan 2017 2:48pm |
A Td5 definitely uses a standard 70A relay for the glow plugs, the timer function is in the engine ECU.
The Tdi timer ECU/relay unit PRC6913 isn't applicable to the Td5, no matter what year. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
18th Jan 2017 3:47pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 573 |
TD5 glow plug relay is controlled from the engine ECU. So just a relay, no timer.
When the engine is cold and runs on low RPM, the ECU energizes glow plugs on running engine. It was a bit surprise for me, hearing unexpected big loud click of some relay, when I was working on 130. In Discovery 2 this is not hear able, the relay is not in seatbox, but in engine compartment. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
19th Jan 2017 9:21am |
That's a couple of times that Dan has quoted the wrong part (unlike him). I wonder if Microcat Live is playing up? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
19th Jan 2017 1:13pm |
