Home > Technical > Connector ident
Baffled 1
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Connector ident
Good evening gents, I am almost finished in tidying up some old wiring within the front console and have found tucked in at the back two connectors. Could you please have a look and let me know what they are four, many thanks.
Jon.
Post #593635 16th Jan 2017 9:52pm
Romadog
Headlamp levelling switch
If you get a switch fitted and get the motors on your headlamps, you will have another feature.
Check in case you have them already.
Make sure you get a Defender switch and NOT a Disco 1 one. They look the same, but have different connection and the different way round.....it just doesn't fit !
Blue one is not a connector, but a means of joining lots of wires together into same circuit called a Header joint.
Thumbs Up
Post #593655 16th Jan 2017 10:18pm
dorsetsmith
natural colour plug
headlight levelling switch plug
Post #593658 16th Jan 2017 10:27pm
Baffled 1
Excellent thanks for your help Thumbs Up
Post #593659 16th Jan 2017 10:30pm
