Home > Technical > BBUS - Don't all Pumas have them? |
you have PM
16th Jan 2017 9:49am |
splatt Member Since: 29 Jun 2012 Location: North Essex Posts: 44 |
Thanks. Dropped you a reply.
So, not all Defenders have them then? Were they a factory fit option? 2008 Defender 110 |
16th Jan 2017 9:58am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
In the early days the BBUS was an optional factory-fitted upgrade, later it became standard on most models, however even then I have met recent vehicles which should theoretically have had one fitted but which have not.
So all in all it is rather pot luck whether you have one or not. The good news is that it is a simple plug and play upgrade, although on TD5s the BBUS-compaitible n/s wing harness was fitted whether or not the BBUS was fitted, whilst on Pumas an economy harness was fitted if the BBUS was not present. To retro-fit to a Puma therefore you will generally need to find a TD5 n/s wing harness. These come up regularly on eBay from breakers. |
Thanks blackwolf, that seems to make sense from what I'm seeing on my Puma.
Fairly sure that I've got the "economy" harness as I can only see sets of wires with two wires in them, see attached. Click image to enlarge 2008 Defender 110 |
16th Jan 2017 10:04am |
For the BBUS you should have a black connector with a rubber shroud with four black wires coming from it.
It can be seen in the photo in the first post in this thread - the connector is the bottom left one in the image |
16th Jan 2017 10:11am |
Ok, great. Thanks. Didn't see anything like that.
Steve 2008 Defender 110 |
16th Jan 2017 10:16am |
http://www.ebay.co.uk/itm/Defender-Harness...SwiONYLxOn
Here you go. Rather more than I'd like to pay, but roughly half the price from a dealer. (Nothing to do with the seller, I just looked for YMD001020 on eBay for you). |
16th Jan 2017 11:09am |
or
alarm plug ------------C1265 Gray plug left hand side heater pins 1 to-----------------------10 3 to-----------------------11 2 to------------------------9 4 to battery neg and used the lead you have now 45min job for good auto sparks http://www.island-4x4.co.uk/part-lr044570-p-27779.html |
16th Jan 2017 11:28am |
Thank both of us, very helpful.
17th Jan 2017 11:55am |
