Home > Maintenance & Modifications > Anti roll bar upgrade. Question. |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
just renew the bushings thats all
the linkage is not adjustable just a piece of metal, while yes I know, there are many fancy options for roll bar linkage for a Jeep |
15th Jan 2017 11:58pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
as above. thats all i did and it was fine. i also fitted superpro bushes
16th Jan 2017 12:29am |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
I replaced the linkages on mine recently as two of the rubber boots had perished and left an angry crater of rust in place..
Lemforder 'OEM' was cheap enough (and actually is the OEM if I'm not mistaken). Without the bar it is quite noticeable with the roof tent on top Solved the bowel problem, working on the consonants... Last edited by agentmulder on 16th Jan 2017 8:54am. Edited 1 time in total |
16th Jan 2017 2:54am |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 |
Did mine a week or so ago and did mull over changing the linkages but the bushes were all good so didn't bother. Just new nylocks on the through bolts - which you should do regardless. ARB comes with new superpro for the 2 clamping points but my brackets were rotted and fell apart when I took them off - so I did change them.
16th Jan 2017 8:50am |
