Home > Tdi > 300tdi coolant hose diameter |
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 |
I need to replace the bottom radiator hose on my 300tdi - the water pump pulley has worn though it somehow..
The bit that's worn is the thin tube which feeds into the pipe running across the top of the engine. It's the shorter of the two narrow pipes forming part 5 on this picture: http://www.lrparts.net/discovery-1-cooling...asket.html My existing pipework is three parts rather than the all in one variety so I'd like to just replace the worn bit rather than all of it. Does anyone know the dimensions of this piece of tubing (I/D and O/D ideally) so that I can source a replacement? Thanks very much! |
13th Jan 2017 11:27am |
That's great, thank you very much
14th Jan 2017 11:07am |
