Home > Puma (Tdci) > oil coming from rear axle outer flange
thrasher
Scotland 2007 Defender 90 Puma 2.4 HT Bonatti Grey
was checking the outer flanges for wear on front and rear axles to rule out the slight drive line clunk when I popped the rear offside rubber cover and oil came out,im presuming inner oil seal but would anything cause this? ie bearings away? axle vent blocked any pointers so I have rough idea what to order?
cheers gus
Post #591611 9th Jan 2017 6:56pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Likely the inner seal on the axle stub.
Not a hard job, biggest issue you will have is the brake caliper bolts.
If you decide you need to stage an intervention, then I would buy new caliper bolts and a seal kit, bolts are cheap and they can be a Censored to get off, so can be damaged, hence why I would replace.
But before doing any of that, I wouldcheck the axle vent isn't blocked....but I would still have money on the inner seal.
Question is, do you do the whole hog and replace the bearings as well, I probably would, along with drive flanges as well.....
Andy
Post #591629 9th Jan 2017 8:21pm
thrasher
cheers andy,will probably replace bearings aswell,i will check breather pipe as there must be a reason for it to happen,im going to do the outer flanges as well will see how it goes, I don't use it every day so being of the road not a big deal
Post #591660 9th Jan 2017 9:34pm
