Home > In Car Electronics > Heated mirror/front screen switch issue |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
Cheapest and quickest option is 3 - the Puma heated seat switch will do what you want. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Jan 2017 1:13pm |
jr1104 Member Since: 05 May 2016 Location: England Posts: 78 |
I'm in the process of planning something similar (one switch for heated front/rear/mirror). In choosing the relay(s) for this, a timed one made more sense for functionality? That way I press it once, and I don't have to remember to turn them off again after driving for a while.
9th Jan 2017 7:21am |
PRC6796 is the original fit timer for the front screen, it normally operates a single relay for the front screen but you could add extra relays 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Jan 2017 10:34am |
Hmm, they used to come up on eBay regularly but seems that's no longer the case 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Jan 2017 10:37am |
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 |
I'll go with that then, thanks for your help |
9th Jan 2017 12:11pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 421 |
Slight Hijack of thread
I would like to put heated seats in on a timer - 10 mins heat at start of journey If I use the front window switch to a GLR10 timer then a relay - will this work The kits from mobile centre seem to have two relays and the orange timer - why two relays Any chance of someone showing the wiring required ? |
19th Jan 2017 7:50pm |
