Home > Wheels & Tyres > Spare question
dioliahary
Spare question
Hi i am going to change my Defencer 90 steel wheels to Alloys ,off a D1. All good to go.
I wondered how to manage the spare wheel. Do I keep it as steel or, woud this compromise the truck in the event of a puncture and having to use the steel wheel with alloys.
I will be using wheel spacers and thought about purchasing an old D1 alloy and changing the spare tyre onto this to keep everything uniform.
Any advice welcome h
Post #590156 4th Jan 2017 7:24pm
Cupboard
It would be nicest to have them all the same, but I wouldn't be too concerned for short term use, like a space saver. I'm pretty sure you can use the alloy wheel nuts on a steel wheel but I'm pretty sure you can't the other way about.
That said it's not going to save you that much cash is it?
Post #590249 4th Jan 2017 10:58pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
WHY ? D1 wheels are a pig to seat tyres on, and due the their age will more than likely be showing age on the inner seat bed.
Post #590284 4th Jan 2017 11:59pm
AMBxx
I used to run steel wheels in winter and alloys in summer. Cheaper to run two sets of wheels than to pay for having the tyres switched twice a year.
I just left an alloy as a spare all year round. Under a wheel cover, I can't see that it makes any difference.
Just don't forget to carry some compatible wheel nuts in case you do need to use the spare!
Post #590310 5th Jan 2017 8:44am
VVS210
The Disco steel rim is compatible with cars fitted with alloys on the road wheels. The wheel nuts for the alloys have a taper on the end of them so they can be used for the steel spare. If in doubt do a check with your wheel & nuts to be certain. I have two sets of tyres on identical Disco Freestyle alloys & a single spare on a disco steel rim for my 90.
Post #590311 5th Jan 2017 8:48am
