Home > Technical > C0929 Grey Connector |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 |
This is the location of the infamous Purple permanent live wire.
I've managed to get myself completely confused as to the wire colour coding Hoping that one of the electrical boffins will be able to confirm if I'm correct. Thanks in advance Click image to enlarge Purple - permanent live Black - earth Blue - fog Green/purple - brake Red/orange - RH tail Red/black - LH tail Green/red - LH indicator Green/white - RH indicator Red/yellow - ??? (wire could be Yellow/red) I only have the 7 pin tow socket and want to change the fog to reverse lights on my trailer and hoping that there will already be reverse feed at the connector... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
4th Jan 2017 3:27pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
At C0929 the fog is red with yellow [RY]. It changes to blue [U] after C0718
Reverse is green with brown [GN], pin 7 of C0929 1988 90 Td5 NAS soft top 2015 D90 XS SW |
4th Jan 2017 3:55pm |
Thanks Martin
From your response it appears my colour blindness is worse than expected as I do not remember seeing green/brown wire, will have you use a friends eyes. If possible, please can you supply me with all the pins/colours for the C0929 connector? Much thanks again Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
5th Jan 2017 7:39am |
You can see the Green/Brown in your photo, just to the left of the Purple
C0929 pinout: 1. Green/Red [GR] Indicator LH 2. Red/Black [RB] Tail LH 3. Green/White [GW] Indicator RH 4. Red/Orange [RO] Tail RH 5. Green/Purple [GP] Brake 6. Purple [P] 12V Permanent from Fuse 5 (20A) 7. Green/Brown [GN] Reverse 8. Red/Yellow [RY] Fog 9. Black [B] Ground 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Jan 2017 2:06pm |
