Home > Expedition & Overland > Rear or side awning on a 110 |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
Click image to enlarge |
5th Jan 2017 2:03pm |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 276 |
Hi Richard.
Quick question regarding your Hannibal awning.... Does it bolt directly to the rear of your rack, or do you need awning extension bars as well? I have the same rack (curved rear corners) but the only pictures I can find are of the awning fitted to the older style Hannibal rack with a straight rear section. Also, does the side kit contain all three sides to completely enclose the back? I'm also tempted by the Nene January discount Just wondering what I need to actually buy. Have posed the same question to Nene but, strangely, there is only one man who can answer that question and he's not there at the moment Tony |
16th Jan 2017 11:23am |
rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128 |
Hi Tony
Yes the brackets for the rear awning bolts directly onto the roof rack. The brackets are on the curved corners. I'll take some pictures tonight and post them. The sides cover all 3 sides and there is a zip door on the back side..not the sides of the awning... I'm not sure if that makes sense. Its hooks that keep the sides up...so quick to erect. I'll have to use bungee cords to keep the awning sides hard up against the sides of my Landy in a windy day, but maybe there is loops for ground stakes..I'm not sure. I've only quickly stuck it up in the dark, I'm sure with a little practice it will be super fast. It seems to give good cover. I hope this helps. Any further questions give me a shout, but I'll stuck up some photos tonight . Cheers Richard |
16th Jan 2017 11:42am |
Hi
A quick picture would be spot on, thanks. Just making sure I know what I need to purchase for the awning to fit. Tony |
16th Jan 2017 1:47pm |
Hi Tony
Here are the photos. Hopefully you can see from the photos there is nothing else to buy. The awning comes with the brackets and screws direct onto the roof rack. Sorry I did not take any photos with it out and the sides on but its cold and wet! cheers Click image to enlarge Click image to enlarge Click image to enlarge |
16th Jan 2017 9:04pm |
They're perfect - thanks very much for braving the cold and wet
It was just the fitting to the back of the rack I wanted to see. Tony |
17th Jan 2017 10:54am |
no problem. cheers
17th Jan 2017 11:01am |
