Home > Tdi > hmmm what goes here.....? |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
is that where the wading plug would go?
30th Dec 2016 12:51pm |
That is the bellhousing drain hole, prior to any jaunt off road / through water you are ment to for the "wade plug" in here to prevent it filling with crap. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
30th Dec 2016 12:53pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Just the wading plug hole, nothing to worry about.
Also used for timing the engine when required. Otherwise all looks quite clean and ordinary Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
30th Dec 2016 12:55pm |
xcentric Member Since: 17 Jan 2016 Location: Midlands Posts: 247 |
thanks, all. Do people actually bother with wading plugs, or not? if so, where to get one (or two) from?
cheers. |
30th Dec 2016 12:57pm |
30th Dec 2016 12:59pm |
I have lost both of mine
They did use to see regular use when I was doing much more regular and deep off road work but in the last year I have not needed them once. Worth getting a pair to keep in your dash in case you need to wade or be in mud that deep. I wouldn't recommend running for long periods with them in as they are useful for letting you know when your seals are leaking and needing replacement. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
30th Dec 2016 9:38pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7683 |
yes they are worth bothering with if you in mud/water alot, especially the timing belt on.
better to fit when needed them remove to allow anything to drain out when they are not fitted. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
30th Dec 2016 10:07pm |
ok I'll show my ignorance where does the other one go then?
31st Dec 2016 12:25am |
One in the bell housing, one in the bottom of the timing belt case Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
31st Dec 2016 12:27am |
here: https://www.google.co.uk/search?q=300tdi+w...N68zlvM%3A
bottom of timing belt housing Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
31st Dec 2016 7:08pm |
