Home > In Car Electronics > 1988 speaker location/options |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6477 |
Under the dash, bottom corners using the spacer rings the factory used (they are cheap).
AMR3840 - £2.66 each plus VAT at full price from Land Rover 1988 90 Td5 NAS soft top 2015 D90 XS SW |
29th Dec 2016 6:09pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
You can fit more modern speakers there you just need a spacer ring.
I made one out of a piece of Mdf cut into a ring and painted black. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
29th Dec 2016 6:12pm |
No way!!!! Upgrading those when I get my truck back Thanks Martin Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
29th Dec 2016 6:14pm |
kenners Member Since: 26 Feb 2015 Location: stoke Posts: 20 |
Great thanks for that I'll get them sorted now. |
29th Dec 2016 7:09pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Above the rear quarter windows is a good spot for speakers.
I fit in a pair of 6 1/2" focal with this kit. Click image to enlarge Click image to enlarge it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
29th Dec 2016 8:53pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 526 |
Hi Kenners..
I've been thinking of the mechless unit. Please Can you let me know which model you went for and what you think when you get it in? Currently I don't have any radio or speakers in my 90 but I'm thinking of using the Mud speaker housings that fit in the back across where the panels are to get into the wiring for the lights. Nice install there CDN |
30th Dec 2016 1:04pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4932 |
CDN38, where did you get that panel for the rear speakers? i am toying with that idea, plus it will be easier to run speaker wires there due to my fronts been in the roof liner. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
31st Dec 2016 12:16am |
I take it I just need to cut a hole on the drivers side? as there is only one on the passenger side?
31st Dec 2016 9:01am |
I have ordered pioneer mvh-160ui ill let you know once its in, I hadn't seen those mudstuff speakers might be tempted with those instead. I have some front speakers from when I bought the landy 2 years ago that im toying with putting in the front with the spacers. |
31st Dec 2016 9:04am |
He makes them and sells them pm him if you want one. Ray My build thread http://www.defender2.net/forum/topic17615.html |
31st Dec 2016 9:56am |
