Home > In Car Electronics > Random fault - radio stays on and cigarette lighter TD5 Def |
Click image to enlarge radio and cigarette feed from the same point on the ignition switch white and orange wire down to the passenger fuse box and also heater 1. Try removing white and orange wire from ignition switch may the switch at play up Last edited by dorsetsmith on 28th Dec 2016 6:46pm. Edited 1 time in total |
28th Dec 2016 6:23pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Sounds like you may have some wear in your ignition switch that could bring up other issues in the near future. Maybe best to look at changing soon.
28th Dec 2016 6:40pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6477 |
Sounds like a failing ignition switch. Note it's only the switch not the key barrel etc.
The switch is cheap enough as an OE aftermarket part (£16) LR035359 / PRC8230 1988 90 Td5 NAS soft top 2015 D90 XS SW |
28th Dec 2016 8:16pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1329 |
Thanks for the assistance there guys. Martin thank you for the parts numbers. I did have an incline it was the ignition switch.
I will get one ordered. Think I need a light stalk too as it doesn't always put beam lights on first time |
28th Dec 2016 10:48pm |
Martin. Those part number say to suit tdi or td4 and not td5.
Do you know if that's right? A quick search finds me this one https://www.ebay.co.uk/itm/291617753245 LR039638 Land Rover Defender Steering Lock Ignition Switch 200 300 TDi TD5 Puma |
28th Dec 2016 10:57pm |
I'm sure you've got this sorted by now but anyway
PRC8230 / LR035359 / LR039638 are all the same. There is nothing different between them, just supercession. The only different switch was the pre-Tdi diesels which had a heavier-duty and physically bigger switch to handle the manual glow plug position. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
4th Jan 2017 2:23pm |
