Home > Td5 > 2001 90 TD5 Stub axle mud shield
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I'm doing some work on the front end stub axles and notice I have one (it looks like this anyway!) on the offside but not the nearside.
www.paddockspares.com/frc2310-stub-axle-mudshield.html
Should I have them? This part, according to the description is not suitable for the 2001. Is there a better number?
[/url] Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #586965 22nd Dec 2016 1:53pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi,
On my 2001 TD5 110, it was fitted on my rear stub axles.
For me it makes sense, it provides another barrier for debris going into the workings between the bearings and seals on the stub.
Might be a difference depending on whether ABS is fitted or not as you'd have a space for the sensor to sit in.
For me if missing I would fit it, but only if I could live with the delivery of the item, i.e. I could live without the car for a few days.
Hope that makes sense.
Andy
Post #586967 22nd Dec 2016 2:03pm
dorsetsmith
Devon 4x4 may have one in stock
Post #586971 22nd Dec 2016 2:23pm
Welkman
Yes I would think so but if you remove the stub axle you will need some 270 loctite on the reassembly. Just done this on my 110 and it would be really easy to forget to put it on if you were replacing the stub axle.
Post #588644 30th Dec 2016 11:19am
MC84
I'll tack a couple onto the next Paddocks order. I won't forget the the Loctite either!" Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #588881 31st Dec 2016 12:18am
