Home > Puma (Tdci) > 2.4 Going into lack of boost mode, CodeP0234 turbo overboost
M94PUMA
Hi all, when I give my 2.4 a heavy pull up an A road in 5th/ 6th gear it goes into half power, basically has no turbo boost, turn it off then back on and it's back to normal. It logs the fault code P0234 turbo overboost condition.
Anyone know where to start looking or had this issue??
I've checked all intercooler pipework and has no splits or hissing noises, so I'm thinking MAF sensor???
Let me know your thoughts please,
Many thanks
Post #585833 17th Dec 2016 6:48pm
M94PUMA
New MAP sensor and problem fixed..
Post #586635 20th Dec 2016 9:44pm
madfrankie
England 2007 Defender 90 Puma 2.4 SW Stornoway Grey
Hi,
Do you mean MAP sensor or MAF as you changed half way through the chain? "Of Course, Of course, I ain't asking . I'm telling!!"
Post #589736 3rd Jan 2017 3:04pm
M94PUMA
Hi it was the MAP sensor I changed,
Post #589748 3rd Jan 2017 3:33pm
Cupboard
Mine kept having that until I got the EGR disabled, but I was getting EGR and MAF errors too.
Post #589903 3rd Jan 2017 10:33pm
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
I know the problem is solved. But I have another solution:
I had the same problem. It was a broken cable from turbo connector.
/Max
Post #594731 20th Jan 2017 3:07pm
