Home > In Car Electronics > Any feedback on eBay trackers
Page 2 of 2 <12
VVS210
gilarion wrote:
I can fully recommend this tracker from ebay at under £28.00, I have three, one as a back up in the Defender, one in my horse trailer and one on my boat accuracy is perfect and does so many things such as texting you if the car is started or moves, its amazing for the price. One of these units is now over three years old and still works perfectly.
http://www.ebay.co.uk/itm/Realtime-Vehicle...SwMgdX1nnx
Am I being a bit dense here? - I thought the idea of a tracker was to be fitted inconspicuously into a car so it could then send a signal with the vehicle's location if pinched without the thief knowing it is even fitted?
This unit looks bulky & the fact it has two aerials which need to be located in suitable places plus additional wiring & a relay etc.
Seems a lot to hide in a 90/110 given how 'sparse' the interior trim is?
Post #582951 5th Dec 2016 10:18pm
AndyB
1989 Defender 90 300 Tdi HT Cairns Blue
The tracker recommended on eBay is great!!
Very accurate, and many useful features.
Only problem is that now, the misses can see if I come straight home from work, or stop off for a sneeky half on my way home !!! Whistle
Andy
Post #586507 20th Dec 2016 11:43am
macfrank
I've also bought the TX103B. Has anyone wired the relay? Not sure what to disconnect on a Diesel to immobilze it.
Post #586738 21st Dec 2016 2:37pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
I've just ordered a 103b and look forward to the thoughts of others on installation. Ian One wife - livid
Post #586744 21st Dec 2016 3:48pm
davew
Does the Puma have an inertia switch under the bonnet like the TD5 does ?
If so then it would make sense to wire a relay into the same circuit using a changeover relay. The inertia switch is hooked up to kill the engine in the case of an accident and it should be easy enough to hide a join in the cable to or from that switch that extends it to your relay.
I've used this myself when wiring up an FIA kill switch to TD5s and also used it as one of the circuits disabled by an aftermarket immobiliser. http://www.yorkshireoffroadclub.net/
Post #586748 21st Dec 2016 4:08pm
Page 2 of 2 <12
