Home > In Car Electronics > Installing rear interior light in 2.2 90 HT |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Complete electrical numpty here but... does the front interior light come on with the rear door? If so can't you just wire in series to the front one? James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
30th Nov 2016 4:49pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1777 |
Ditto. Good question and I should have said - but no it doesn't, so thanks for prompting me to clarify.
30th Nov 2016 5:14pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
The front light should come on with the rear door...
And you mean in parallel. If you wire them in series then each one will get 6V (nominally). |
30th Nov 2016 5:32pm |
Aaaarg it does! Forgot I turned it off due to the glowing led issue, sorry.
But, the question still remains how are they 'factory' wired? |
30th Nov 2016 5:36pm |
See I knew I shouldn't have commented Just didn't want you to think your post was being ignored James
30th Nov 2016 5:47pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16881 |
When I fitted a second interior Mud LED light over the second row seats in my DC, I simply connected it in parallel to the exisiting front row Mud LED light, so each of the three terminals is connected to the same terminal of the other light.
This means that they come on together from the AS10 (ie unlock, engine off, and door opening) and can be switched individually between AS10, OFF, and ON. Simple, and works a treat. |
30th Nov 2016 5:56pm |
Ok, sounds good, thanks. I had assumed there may be an off the shelf loom, but please advise to do a proper job what wire and connectors I should be looking to get
Thanks. |
30th Nov 2016 6:04pm |
I added a third interior light in my 110 SW, I put one over the second row seats in addition to the one by the interior mirror and one at the very back in the cargo area. I was finding the second row seats were very dark and the extra light is very welcome. All that I did was to tap into the wires that were allready above the roof lining going from front to back. I am using leds with no hassle.
30th Nov 2016 10:19pm |
I'd use crimp splices myself. Quick, easy, good joints.
1st Dec 2016 2:01pm |
