Home > Technical > 'ENG' 5A fuse F5
Tumbiri
2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
'ENG' 5A fuse F5
2013 PUMA 2.2L. Found the F5 (ENG ECU/PCM) fuse is not installed . See photo. Am told not all Defenders have this fuse. Is this correct or should I put one in?
Post #581371 29th Nov 2016 7:22pm
Martin
Site Admin
According to the 2012 MY wiring diagrams it doesn't go anywhere, so it not being fitted is fine.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #581376 29th Nov 2016 7:37pm
Tumbiri
Thanks Martin
Post #581377 29th Nov 2016 7:46pm
abyss
Australia
My 15’ puma 2.2 also didn’t have F5 and F6 fuse installed either? What happen if I put the fuse back in?
Post #658846 21st Oct 2017 10:58pm
Tumbiri
It seems that F5 doesn't go anywhere so putting the fuse in would do nothing. F6 on my 2013 MY is for the ABS and the fuse is installed. What is F6 on yours?
Post #658854 21st Oct 2017 11:32pm
abyss
Australia
Just checked F6 has a 10amp in it for ABS. My bad.
Tried to put the 5amp in F5 but it doesn’t have any contact in so won’t hold the fuse.
Guess is all good
Post #658859 22nd Oct 2017 1:44am
Tumbiri
Good to go!
Post #658860 22nd Oct 2017 1:49am
