Home > My Defender > Grafty's Td5 90 |
They were. Although these are off a puma 2002 90 Td5 Station Wagon
29th Mar 2017 10:52pm |
The engine, chassis, axles and seatbox forwards is still original 2002 90 Td5 Station Wagon
29th Mar 2017 10:55pm |
Is putting your defender on the ramp to grease the prop shafts considered excessive use?
Usually do it on the floor but thought "why not?" 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
31st Mar 2017 8:28pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10358 |
I'd wash it on the ramp too, no bending down!
31st Mar 2017 9:54pm |
might make a bit of a mess in the workshop 2002 90 Td5 Station Wagon
31st Mar 2017 9:59pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Grafty got the drl light stemp wired up till tomorrow
Click image to enlarge Click image to enlarge 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
1st Apr 2017 8:30pm |
Look better in person doesn't photo to well 2008 110 2.4 XS Utility (Hagrid)
Looks good! Very bright 2002 90 Td5 Station Wagon
2nd Apr 2017 10:34pm |
Well yesterday I had a very stark reminder. Change your wheel bearings in pairs!
On the way to the Defender Day at Pentille Castle ( got it this time Clayton ) My O/S/Front wheel bearing collapsed at speed (60mph) I replaced the N/S/Front bearings last week after it started to grumble, whilst at it I inspected the other 4 and there was no noise or play in the others. This is the result (skip to 3 minutes in) https://drive.google.com/file/d/0BymT3xBHs...p=drivesdk No warning at all - If this had happened a couple of seconds later I would have been toast and if I had replaced the front bearings as a pair it wouldn't have happened at all. Thanks again to Clayton for the lift home - my defender got home 2 hours after I did. And its the first time I have called the AA in my 9 years of ownership 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
3rd Apr 2017 11:10pm |
Well I have started to strip the O/S front. Looking like a new stub axle is required
Click image to enlarge Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
4th Apr 2017 8:07pm |
It is amazing that it gave no warning and no noise before hand as it looks pretty dry. Although I suppose the heat could have burnt off and remaining grease 2002 90 Td5 Station Wagon
4th Apr 2017 8:09pm |
Time too check three more hubs
4th Apr 2017 8:32pm |
Well I changed the N/S a couple of weeks ago and checked the other 3 then. There was no indication of a problem when I checked which is the worrying part
I will remove all the hubs and re grease and internally inspect them all this weekend 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
4th Apr 2017 8:52pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4932 |
I have to do my fronts for the test, so god knows what I will face! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
5th Apr 2017 6:04am |
