Home > Tdi > Discovery 200TDI what bits will fit 200TDI 90 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2545 |
Gearbox - shift position can be sorted with an adaptor and your old shift housing, however as you say the input shaft is the wrong length for a 200Tdi Defender.
Transfer box - will fit more or less, but likely to be a different ratio. I put a Discovery/RRC handbrake in my 90 a while back, which helps with comfort and ease of use. |
20th Nov 2016 10:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7682 |
tbox will be 1.2 on disco, 1.4 on pre puma defenders 1.2 on puma defenders
handbrake lever handbrake drum engine gbox with a few changes front axle rear axle calipers radius arms trailing arm seats rims Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
21st Nov 2016 1:46pm |
