Home > In Car Electronics > Heated Front Screen - Diamondback Bison |
heated front screen main fuse
fuse 36 centre fuse box td5 30amp 2002 onwards control fuse 15 5 amp centre fuse box NO earth point in the centre fuse box earth point K108 in engine bay behind coolant expiation tank next one driver side box 6mm stud Click image to enlarge if you have TD5 1999 to 2002 with no A/C fitted fuse 9 or 10 centre fuse box is for ac power and fuse 7 can be used control supply will have wiring to it as also supply rear heated window best i can do with no age or model type |
20th Nov 2016 10:05am |
Lund Member Since: 04 Jul 2016 Location: United Kingdom Posts: 49 |
All sorted thank you. In short; the wire's I didn't think would reach - did reach!
PS. This is an aftermarket kit,and doesn't utilize the original wiring/fuses. Thanks |
21st Nov 2016 1:12pm |
